Einleitung
If the power button is unresponsive or stuck, it may need to be cleaned or replaced. This guide will help you remove the button from the camera body.
Was du brauchst
Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
To remove the hand-strap, pull the Velcro strip through the leather pad.
Press in the battery release tab located on the bottom of the camera.
Slide the battery out from the body.
Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
Open the display screen and remove the three 5mm Phillips #00 screws.
Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
Use the plastic opening tool to undo the bronze ribbon connector.
Remove one 4mm Phillips JIS#00 screw located on the top of the camera near the battery connection.
Pull the plastic casing away from the camera. The speaker and power button are housed in this casing.
Remove four 5mm Phillips PH#00 screws holding the speaker bracket in place.
Remove one more 5mm screw below the power button.
Using a pair of tweezers, gently push in the red tabs of the power button.
Pull the power button out of the camera casing.
