Einleitung
This guide will aid you in removing and replacing your SD Card.
Open the screen compartment.
Position the camcorder so that the screen is facing you.
Find the SD card compartment.
Place your finger under the slot and gently slide it forward to open the compartment.
Gently push on the SD card until you hear a "click". The SD card should pop out.
Remove the old SD card by pulling it out.
Fast fertig!
Abschluss
