Zum Hauptinhalt wechseln
Canon Vixia HF S10 Camcorder Audio Replacement
Was du brauchst
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: Schritt 1, Bild 1 von 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: Schritt 1, Bild 2 von 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: Schritt 1, Bild 3 von 3
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: Schritt 2, Bild 1 von 3 Canon Vixia HF S10 Camcorder Audio Replacement: Schritt 2, Bild 2 von 3 Canon Vixia HF S10 Camcorder Audio Replacement: Schritt 2, Bild 3 von 3
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: Schritt 3, Bild 1 von 3 Canon Vixia HF S10 Camcorder Audio Replacement: Schritt 3, Bild 2 von 3 Canon Vixia HF S10 Camcorder Audio Replacement: Schritt 3, Bild 3 von 3
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
Abschluss
Clint
101 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 13-1, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 13-1, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G1
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 640
