Einleitung
These simple steps will help you replace the strap handle of your Canon Vixia HF S10 camcorder.
Was du brauchst
Flip the camcorder upside down and remove the four 2.5 mm Phillips #00 screws from the bottom of the camera and two 2.5 mm screws from the top of the camera.
Unhook the strap.
Using a plastic opening tool, outline the edges.
Remove the plastic casing.
Remove the single 2.5 mm Phillips #00 screw securing the silver plate.
Using your fingers, remove the silver plate.
Remove the strap to have it replaced.
