Einleitung
If you need to replace the bottom conical burr, follow this guide to access it. The bottom conical burr is essential to having finely ground coffee, and if it is dull or no longer working, it needs to be replaced. For this guide you will need a Torx Security T20 Bit Screwdriver and an extension bit. To access the bottom conical burr, you will need to follow previous guides on replacing the outside metal casing. This guide is simple once you’ve finished the other.
Was du brauchst
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Flip entire device upside down.
Remove two rubber coverings on the back of the device.
Lift the metal outside casing off the black base.
Flip the outside casing forward so you have access to the inside of it.
Remove one 11.59mm T10 screw.
Let the green wire fall, or place somewhere so it doesn't get in the way.
Grab the edge of the plastic black ring that sits on top of the device and gently pull up to release.
Grip the plastic piece at the top of the conical burr and pull upwards to remove.
Grip the metal burr, and pull upwards to slide it off the plastic base.
This is the correct position of bearings and springs when the screw and bottom burr are removed.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
Step 5. In my machine there are 5 taps im bottom that has to be released with a screwdriver, before outer cap can be liftet up.
Step 9, It is essential to mark the location of black plastic ring in regards to white plastic part with holes AND in regards to ex. white square plastic part before removing part. Othervise you can’t assemble or you could destroy the burrs when you adjust the grinder to very fine grinds
Hi is it possible to remove the top burr? If yes how?
Thanks
Great description of how to remove the bottom burr. Would be even greater if a new burr was available, which it is not.
wow - Appreciate the instructions but…….screw this….$85 for a new whole new Capresso Infinity Conical Grinder….. https://www.amazon.com/gp/product/B0000A...
