Einleitung
Does your Capresso Infinity Coffee Grinder not turn on? Has the power cord started to fray? If so, there might be an issue with your power cord. Here is a guide to replace your Capresso Infinity power cord. All you need is a Torx Security T10 Bit Screwdriver and a 2.0 Flathead Screwdriver in order to remove the screws to replace the power cord.
Was du brauchst
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Flip entire device upside down.
Remove two rubber coverings on the back of the device.
Lift the metal outside casing off the black base.
Flip the outside casing forward so you have access to the inside of it.
Remove one 11.59mm T10 screw.
Let the green wire fall, or place somewhere so it doesn't get in the way.
Using a Flathead screwdriver loosen the two screws connecting the white and black wire to the plastic box.
Originally attached to the inside of the outer casing, the green wire needs to be fed through the zip tie which keeps it in place.
Lift up on the zip tie far enough to create a space to feed the green wire through.
Place the zip tie back around the column that you lifted it from.
All three wires that comprise the power cord should be detached from the coffee grinder.
Feed the wires through the small hole at the bottom of the coffee grinder where the external power cord is located.
Once the power cord is free of the coffee grinder, you are able to put in the new cord.
