Einleitung
If you need to repair any of the wires or computer chips, use this guide to remove these components for repair and replacement.
Was du brauchst
Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
Remove the two 7.5mm Phillips #2 screws from the metal frame.
Remove the frame from the assembly.
Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
Find the cable that attaches the small computer chip to the heating element connections.
Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
Push the latch off the tab with the spudger.
Identify the two computer chips that connect the two yellow wires to the temperature controls.
Remove the four 5 mm Phillips #1 screws.
Remove the two computer chips from their places.
Find the computer chip over the dial.
Remove the three 6mm Phillips #2 screws.
Remove the computer chip.
Eine weitere Person hat diese Anleitung absolviert.
