Was du brauchst
Lift the lid of the Perfectea
Remove the two 12mm Phillips #2 screws located at the brim of the pot.
With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
Firmly grip the glass pot with one hand while using the other to slip the flat end of the plastic opening tool between the glass pot and the adhesive tape holding the handle to the glass pot.
Gently pry the adhesive tape from the glass pot. Work your way around the handle until the handle is loose and not attached to the pot anymore.
Once the handle is loose, locate the four 10 mm Phillips #2 screws from the base of the Perfectea and remove them.
Remove the base.
Locate the two 10 mm Phillips #2 screws at the bottom of the handle and remove them.
In order to free the bottom of the handle, remove the plastic piece that was held by the two screws
While firmly holding the glass pot, gently slide the bottom of the handle up and out of the base of the pot.
The bottom panel has four wires that latch on to four tabs.
Use the metal spudger to pry up one metal tab in the latch.
Apply pressure with the metal spudger to the other tab on the latch to slide off tab.
Repeat for the remaining three tabs.
The bottom panel should now be disconnected from the rest of the kettle.
Remove the 7mm nut using needlenose pliers or a 7mm nut driver.
Remove the metal washer and red washer that is under the nut.
Wiggle loose and remove the metal brace.
Wedge a plastic opening tool under the rubber seal on the inside of the kettle.
Work the plastic opening tool around to loosen the seal and push the heating dome out of its hole.
Remove the heating dome from the kettle.
Peel the seal off of the heating element.
Draw the two temperature probe wires through the seal.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
This guide applies almost identically to the Capresso H2O kettle, which doesn't have the control board. Thanks for the guide.
