Einleitung
This guide will teach you how to replace the motherboard within the Capresso Perfectea.
Was du brauchst
Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
