Zum Hauptinhalt wechseln
Capresso Perfectea 260 Motherboard Replacement
Was du brauchst
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: Schritt 2, Bild 1 von 2 Capresso Perfectea 260 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: Schritt 5, Bild 1 von 2 Capresso Perfectea 260 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Lift the motherboard out of the device
Abschluss
Rohin Chander
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-17, Maness Spring 2015 Mitglied von Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 236
