Zum Hauptinhalt wechseln
Car Key Fob Battery Replacement
Was du brauchst
  1. Car Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 1 von 3 Car Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 2 von 3 Car Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 3 von 3
    • Unscrew the single Phillips screw on the back of the key fob using a #1 Phillips screwdriver.
    • The two black plastic pieces should separate, revealing the control module. Lift out the control module from the rest of the key.
  2. Car Key Fob Battery Replacement: Schritt 2, Bild 1 von 3 Car Key Fob Battery Replacement: Schritt 2, Bild 2 von 3 Car Key Fob Battery Replacement: Schritt 2, Bild 3 von 3
    • There are four plastic retaining clips that hold the control module intact.
    • Starting with the smallest retaining clip, insert the flat end of a spudger in between the black and white plastic pieces of the clip in order to release its hold.
    • Rotate the control module to the next retaining clip, taking care not to accidentally clamp down the previously-released clip. Repeat the same procedure in the previous bullet to release the other two retaining clips.
    • Once all four clips are released, separate the white plastic piece from the rest of the control module.
  3. Car Key Fob Battery Replacement: Schritt 3, Bild 1 von 3 Car Key Fob Battery Replacement: Schritt 3, Bild 2 von 3 Car Key Fob Battery Replacement: Schritt 3, Bild 3 von 3
    • The CR1620 battery is held in place by metal contacts. Use the pointy end of the spudger to release the battery from the metal contacts.
    • Swap in a new CR1620 battery, and make sure it is securely held in place by the metal contacts.
  4. Car Key Fob Battery Replacement: Schritt 4, Bild 1 von 2 Car Key Fob Battery Replacement: Schritt 4, Bild 2 von 2
    • Optional: Use the pointy end of the spudger to remove some of the gunk/buildup within the key fob.
    • Insert the control module back into the key fob, making sure all the buttons line up with the holes.
    • Reattach the two halves of the key fob on the side opposite of the key first, then continue until the entire fob is back together in its original state.
    • Don't forget to put back the Phillips screw!
Abschluss
24 weitere Nutzer:innen haben diese Anleitung absolviert.
19 Kommentare
All fine and good, except the identical looking key fob from my 2010 Outback uses a CR1620 battery. So much for the CR2025s I bought!
janetsutton - Antwort
Nice, clear description of the process (which is very simple). My 2010 Outback also uses the CR1620 battery, not the CR2025 the instructions say. I would recommend disassembling your key fob and taking the old battery to the store to compare. You can still drive with the disassembled key fob; you just have to lock/unlock the door manually.
Mark Ray - Antwort
Great instructions! However, just like Mark and Janet, my 2010 Legacy keys had a CR1620 battery. Also, there were 4 plastic clips on step 2. Thanks for the guide!
Steve Osgood - Antwort
Apparently the instructions have been updated since the above comments, because they now call for the CR1620, which is what I bought, and they work perfectly!
The instructions and photos are very clear, easy to follow, and accurate. I was very pleased to find this site and realize that for about 15 bucks total I could replace the batteries in both our 2010 Outback keys - I had imagined we'd have to get new keys or at the least take them to the dealer for a highly pricey replacement. Thanks, ifixit!!
Gurukarm Khalsa - Antwort
Question, I replaced mine but it still doesn't work. do I need to reset the system?
Jessica Fraley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 100
Letzte 30 Tage: 451
Insgesamt: 283,019
