Zum Hauptinhalt wechseln
Car Seat Belt Stopper Replacement
Was du brauchst
    1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: Schritt 1, Bild 1 von 1
      • Use a cloth to wipe away any debris from the area.
      Frag FixBot
      Kommentar hinzufügen
    2. Car Seat Belt Stopper Replacement: Schritt 2, Bild 1 von 1
      • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
      • Separate the replacement stopper if it has come assembled.
      Frag FixBot
    3. Car Seat Belt Stopper Replacement: Schritt 3, Bild 1 von 1
      • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
      • Push the side of the seat belt button with the needle or point into your desired location.
      • It may require a small amount of force.
      Frag FixBot
    4. Car Seat Belt Stopper Replacement: Schritt 4, Bild 1 von 1
      • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
      • Fasten the two parts of the button together and squeeze for a secure fit.
      • You may hear a "snap" or "click" when they are fastened together.
      Frag FixBot
    5. Car Seat Belt Stopper Replacement: Schritt 5, Bild 1 von 1
      • Check the position of the replacement stopper for a comfortable fit.
      Frag FixBot
    6. Car Seat Belt Stopper Replacement: Schritt 6, Bild 1 von 1
      • Now you can use the seat belt buckle without it falling down!
      Frag FixBot
Abschluss
Changing your positioning of replacement can be used to your liking.
Eine weitere Person hat diese Anleitung absolviert.
UC Davis, Team 4-1, Whithaus Spring 2024 Mitglied von UC Davis, Team 4-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 42
Letzte 30 Tage: 171
Insgesamt: 3,254
