Zum Hauptinhalt wechseln
Carburetor Disassembly
Was du brauchst
  1. Carburetor Disassembly, Remove air filter + housing: Schritt 1, Bild 1 von 3 Carburetor Disassembly, Remove air filter + housing: Schritt 1, Bild 2 von 3 Carburetor Disassembly, Remove air filter + housing: Schritt 1, Bild 3 von 3
    • Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter.
    • Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
  2. Carburetor Disassembly, Remove carburetor: Schritt 2, Bild 1 von 3 Carburetor Disassembly, Remove carburetor: Schritt 2, Bild 2 von 3 Carburetor Disassembly, Remove carburetor: Schritt 2, Bild 3 von 3
    • Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench.
    • Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around.
    • The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 37
Insgesamt: 1,140
