Zum Hauptinhalt wechseln
Carburetor Idle Adjustment
Was du brauchst
  1. Carburetor Idle Adjustment, Carburetor Idle Adjustment: Schritt 1, Bild 1 von 2 Carburetor Idle Adjustment, Carburetor Idle Adjustment: Schritt 1, Bild 2 von 2
    • Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
    • Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
    • Start the engine
  2. Carburetor Idle Adjustment: Schritt 2, Bild 1 von 2 Carburetor Idle Adjustment: Schritt 2, Bild 2 von 2
    • Allow time for the engine to warm up completely
    • Attach carburetor synchronization tool to one of the carburetors
    • Observe the relative reading, and remember it.
    • This reading is a measurement of the airflow speed
  3. Carburetor Idle Adjustment: Schritt 3, Bild 1 von 1
    • Set the synchronization device on the other carburetor.
    • Using a Flathead screw-driver, twist the idle speed screw in to raise the flow, and out to lower it.
    • Recheck both carburetors and adjust as needed to get the flow as equal as possible.
  4. Carburetor Idle Adjustment: Schritt 4, Bild 1 von 2 Carburetor Idle Adjustment: Schritt 4, Bild 2 von 2
    • Now, the idle mixture screws must be adjusted.
    • It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
    • Turn both screws in, or out an 1/8 or a turn at a time until the fastest idle speed is achieved.
    • Before proceeding with this step you should have already checked your ignition timing, if you have not do it now, and then continue from here.
  5. Carburetor Idle Adjustment: Schritt 5, Bild 1 von 1
    • Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
    • Once more, it is important to adjust the screws the same amount.
    • Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
Abschluss
Congratulations, your Corvair should now idle properly. If the Carburetors are still not operating properly, then the linkage is not synchronized, or they are in need of repair or rebuild. (A linkage adjustment and rebuild guide will be made soon!)
26 weitere Nutzer:innen haben diese Anleitung absolviert.
Noah
568 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-33, Regan Fall 2012 Mitglied von Cal Poly, Team 6-33, Regan Fall 2012
CPSU-REGAN-F12S6G33
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Bonjour,
Ma corvair a 4 carburateurs.
Est-ce que le ralenti se règle individuellement sur chaque ?
Merci
Stéphane Decottignies - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 62
Letzte 30 Tage: 259
Insgesamt: 62,324
