Zum Hauptinhalt wechseln
Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
Was du brauchst
Angehängtes Dokument
  1. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement, Flow Sensor Receptacle: Schritt 1, Bild 1 von 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4 Phillips pan-head screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 4, Bild 1 von 1
    • Remove all six small side panel screws along the bottom of each side of the top cover.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 6, Bild 1 von 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
  6. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 9, Bild 1 von 1
    • Remove the 2 Phillips countersink screws from the right side of the rear panel.
  7. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 10, Bild 1 von 1
    • Remove the 1 Phillips countersink screw in the upper front of the right panel.
  8. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 11, Bild 1 von 1
    • Remove the 1 Phillips pan-head screw in the lower center of the right panel.
  9. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 12, Bild 1 von 1
    • Gently lift out the panel and the power PCB. Lay the panel flat and make the following disconnections:
    • Remove the 2 Phillips countersink screws at the rear of the left panel.
    • Remove the 1 Phillips countersink screw in the upper front of the left panel.
    • Lift out the left panel.
    • Disconnect the following from the main PCB:
    • JP2 40-pin ribbon cable to JP1 on the SVGA out PCB
    • J301 12-pin to J301 on the blender PCB
  10. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 15, Bild 1 von 1
    • Disconnect the green oxygen nebulizer tube
    • Remove the 2 Phillips pan-head screws behind the front panel at the lower left and right.
    • Disconnect the 1/8” silicone tube #4 from P2 on the exhalation differential transducer
    • Disconnect the 1/8” silicone tube #5 from P1 on the exhalation differential transducer
    • Disconnect the 1/8” silicone tube #1 from the turbine
    • Disconnect the 1/16” silicone tube from the front ports of the turbine outlet auto-zero solenoid that goes to the main tubing harness.
    • Disconnect the 1/16” silicone tube from the turbine inlet auto-zero solenoid that goes to the turbine.
    • Disconnect the 1/16” silicone tube from the airway pressure auto-zero solenoid that goes to the exhalation valve receptacle.
  11. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 17, Bild 1 von 1
  12. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 18, Bild 1 von 1
  13. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 19, Bild 1 von 1
    • Loosen 7 Phillips pan-head screws on the main PCB.
    • Lift the main PCB out of the front panel.
  14. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 21, Bild 1 von 1
    • Disconnect the 2 1/16” ID tubes to the main tubing harness
  15. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 22, Bild 1 von 1
    • Disconnect the grey 6-pin connector.
  16. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: Schritt 23, Bild 1 von 1
    • Remove the 2 1/4” nuts on the flow sensor PCB.
    • Lift off the flow sensor PCB
Abschluss
Angehängte Dokumente
Ethan Nikcevich
649 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S11-G22, Paton Spring 2020 Mitglied von Cal Poly, Team S11-G22, Paton Spring 2020
CPSU-PATON-S20S11G22
2 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 231
