Zum Hauptinhalt wechseln
Cardinal Health Vela Ventilator Left Panel Replacement
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
Was du brauchst
  1. Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Power Cable Removal: Schritt 1, Bild 1 von 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: Schritt 3, Bild 1 von 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Left Panel Replacement: Schritt 4, Bild 1 von 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Achtung: Die Schritte 6-8 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Battery Tray Removal: Schritt 6, Bild 1 von 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Left Panel Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
Abschluss
Tanner Hillman
370 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S7-G22, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G22, Paton Spring 2020
CPSU-PATON-S20S7G22
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 106
