Einleitung
In order to operate on the interior of the ventilator where the battery, fans, and tubes are, the top cover of the ventilator must first be removed. This guide details how to take the top cover off. Make sure the ventilator is unplugged before attempting to disassemble to prevent electrical shock.
Was du brauchst
Schritt 1 Cardinal Health Vela Ventilator Power Cable Removal
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
