Zum Hauptinhalt wechseln
Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement
Was du brauchst
  1. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: Schritt 1, Bild 1 von 2 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: Schritt 1, Bild 2 von 2
    • Unplug the unit before disassembling to avoid electrocution.
    • Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
  2. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: Schritt 2, Bild 1 von 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: Schritt 2, Bild 2 von 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: Schritt 2, Bild 3 von 3
    • Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
    • With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
  3. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: Schritt 3, Bild 1 von 2 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement: Schritt 3, Bild 2 von 2
    • Once you have the halves opened at least 1/4'', remove the metal key and rotate the base a quarter turn in any direction.
    • Continue using the spudger to pry open the base at each quarter turn until the sides separate easily.
    • The black bottom will catch on the power cord plug, to prevent total dismantlement.
  4. Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: Schritt 4, Bild 1 von 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: Schritt 4, Bild 2 von 3 Caribou Coffee CC-EKV8SS7 Safety Shutoff Mechanism Replacement, Safety Shutoff Mechanism: Schritt 4, Bild 3 von 3
    • To uninstall the element, start by removing the 4 copper connectors and 1 metal tab from the power cord. This will require you to wiggle and pull the connectors out.
    • Once those pieces are detached, you can insert them into the replacement part, as they were.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S1-G3, Liner Summer 2017 Mitglied von UW Tacoma, Team S1-G3, Liner Summer 2017
UWT-LINER-SU17S1G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 429
