Zum Hauptinhalt wechseln
Carlo Robelli CBW-4134CR Piezo Pickup Replacement
Was du brauchst
  1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: Schritt 1, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: Schritt 1, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: Schritt 1, Bild 3 von 3
    • Unwind the low E guitar tuner with a guitar winder to loosen the string.
    • Cut the string above the sound hole using a string cutter.
  2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 2, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 2, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 2, Bild 3 von 3
    • Remove the low E string from the guitar tuner and remove the bridge pin.
  3. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 3, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 3, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 3, Bild 3 von 3
    • Repeat Steps 1 and 2 for the rest of the guitar strings, removing all the pins and strings.
    • Remove the bridge saddle.
  4. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 4, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 4, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 4, Bild 3 von 3
    • Find the preamp box inside the guitar soundhole and disconnect the piezo pickup only.
  5. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 5, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 5, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 5, Bild 3 von 3
    • Inside the guitar, find the piezo pickup and push outward.
    • Once the pickup is sticking out, pull to remove it.
  6. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 6, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 6, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 6, Bild 3 von 3
    • Grab the new piezo pickup and insert it in the designated hole, pressing firmly and ensuring it is neatly tucked in.
  7. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 7, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 7, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 7, Bild 3 von 3
    • Once the piezo pickup is inside the guitar, connect the pickup to its proper input inside the guitar preamp.
  8. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 8, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 8, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 8, Bild 3 von 3
    • Place the bridge saddle back in place.
    • Insert a new set of strings with guitar pins to ensure that the line is not pulled out when winding the new guitar strings.
  9. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 9, Bild 1 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 9, Bild 2 von 3 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 9, Bild 3 von 3
    • Once all new strings are wound up, cut off the excess line for a neater look.
  10. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: Schritt 10, Bild 1 von 1
    • This is how the bridge should look once everything is back into place.
Abschluss
Having a new piezo pickup will heavily improve the sound quality sent from your guitar to the guitar amplifier, recording interface, PA system, or headphones.
Bryant Castor
181 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 8-88, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 8-88, Briggs Spring 2022
CSULA-BRIGGS-S22S8G88
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 354
