Zum Hauptinhalt wechseln
Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement
Was du brauchst
  1. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement, Axle Replacement Guide: Schritt 1, Bild 1 von 1
    • Flip the car with the bottom side facing up.
    • Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
    • Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
  2. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: Schritt 2, Bild 1 von 1
    • Place the new axle where on the curved side is pointed towards center.
    • Screw it into place but make sure it isn't too tight. The axle needs to able to move a bit.
  3. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: Schritt 3, Bild 1 von 1
    • Repeat the same steps for the back axle of the car but without concern of the curved part.
  4. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: Schritt 4, Bild 1 von 1
    • Place the new wheel into the car and attach the new screw
Abschluss
USF Tampa, Team S3-G5, Cannon Fall 2017 Mitglied von USF Tampa, Team S3-G5, Cannon Fall 2017
USFT-CANNON-F17S3G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 806
