Einleitung
How to replace the axles.
Was du brauchst
Flip the car with the bottom side facing up.
Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
Repeat the same steps for the back axle of the car but without concern of the curved part.
Fast fertig!
Abschluss
