Was du brauchst
Using the Philips screwdriver, unscrew the back wheel by turning the screw located on the middle of the wheel, while holding the wheel in place
Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
Place the new wheel into the car and attach the new screw.
Repeat the same steps for the other side of the car.
Fast fertig!
Abschluss
