Zum Hauptinhalt wechseln
Carrier 58MSA060-08 Furnace Filter Replacement
Was du brauchst
  1. Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: Schritt 1, Bild 1 von 2 Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: Schritt 1, Bild 2 von 2
    • Locate the furnace disconnect switch.
    • Flip the switch from the "ON" position to the "OFF" position.
  2. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 2, Bild 1 von 1
    • The filter is located in between the return duct and the main furnace unit.
  3. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 3, Bild 1 von 3 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 3, Bild 2 von 3 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 3, Bild 3 von 3
    • Pull the filter cover off of the duct to remove it and expose the filter.
  4. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 4, Bild 1 von 2 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 4, Bild 2 von 2
    • Examine your furnace to determine the air flow direction.
    • The Return Duct
    • The Furnace Unit
    • The air will always flow from the return duct towards the furnace unit.
    • Your old filter may also have an arrow indicator on the side.
    • The arrow's direction will indicate the air flow direction.
  5. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 5, Bild 1 von 3 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 5, Bild 2 von 3 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 5, Bild 3 von 3
    • Remove the old filter by pulling it out of the duct.
  6. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 6, Bild 1 von 3 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 6, Bild 2 von 3 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 6, Bild 3 von 3
    • Insert the new filter.
    • Pay attention to which direction the new filter should face before inserting it; make it is correct.
  7. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 7, Bild 1 von 2 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 7, Bild 2 von 2
    • Reattach the filter cover.
    • Ensure that the filter cover is securely in place.
  8. Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 8, Bild 1 von 2 Carrier 58MSA060-08 Furnace Filter Replacement: Schritt 8, Bild 2 von 2
    • Turn on the furnace.
    • Flip the switch from the "OFF" position to the "ON" position.
Abschluss
Once you have completed these steps, your furnace filter replacement will be complete.
2 weitere Personen haben diese Anleitung absolviert.
York University, Team R-29, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-29, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG29
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 43
Letzte 30 Tage: 200
Insgesamt: 6,051
