Einleitung
Furnaces are one of the most important appliances in a household but they are often neglected. As a result, when they do breakdown, homeowners face expensive repair or replacement costs.
The simple maintenance task of changing your furnace’s filter will provide many benefits such as:
- Extending the furnace’s lifespan.
- Increasing the furnace’s efficiency.
- Improving the air quality within your home.
This guide will teach you how to replace the furnace filter in a Carrier 58MSA060-08 furnace.
Was du brauchst
Locate the furnace disconnect switch.
Flip the switch from the "ON" position to the "OFF" position.
Examine your furnace to determine the air flow direction.
The Return Duct
The Furnace Unit
Your old filter may also have an arrow indicator on the side.
Turn on the furnace.
Flip the switch from the "OFF" position to the "ON" position.
Once you have completed these steps, your furnace filter replacement will be complete.
2 weitere Personen haben diese Anleitung absolviert.
