Zum Hauptinhalt wechseln
Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement
Was du brauchst
  1. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement, Capacitor: Schritt 1, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement, Capacitor: Schritt 1, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement, Capacitor: Schritt 1, Bild 3 von 3
    • To ensure complete safety, turn off the power supply from the electrical panel or disconnect switch.
    • Wait for a few minutes to allow any electrical charge to dissipate. This will ensure safety and prevent any potential hazards.
  2. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 2, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 2, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 2, Bild 3 von 3
    • Use an insulated socket wrench to remove the four 38 mm bolts that secure the access panel to your AC unit.
  3. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 3, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 3, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 3, Bild 3 von 3
    • Open the panel carefully.
    • Capacitors are usually cylindrical in shape and come in different sizes.
    • It's a good idea to either take a photo or make a note of the wiring for future reference.
  4. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 4, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 4, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 4, Bild 3 von 3
    • To remove the old capacitor, carefully unscrew the mounting brackets and disconnect the wires.
    • When you disconnect the wires, make sure to wear safety gloves.
    • Make sure to take note of the exact location where each wire connects.
  5. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 5, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 5, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 5, Bild 3 von 3
    • To remove the old capacitor, first unscrew or unclamp it from its mount.
    • If the capacitor is secured with screws, use a screwdriver to carefully remove them. If it's clamped in place, use an appropriate tool to unclamp it.
    • Carefully note down the specifications of the old capacitor for the replacement.
  6. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 6, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 6, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 6, Bild 3 von 3
    • Secure the new capacitor and make sure it is securely mounted or clamped in place.
    • Carefully reconnect the wires to the corresponding terminals on the new capacitor.
    • It is crucial to connect the wires correctly by matching the color-coded or labeled wires to the appropriate terminals on the capacitor.
    • Wear gloves when handling the capacitor to prevent electrical shocks.
  7. Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 7, Bild 1 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 7, Bild 2 von 3 Carrier Performance™ 17 2-Stage AC Unit Capacitor Replacement: Schritt 7, Bild 3 von 3
    • Place the access panel cover securely back onto your AC unit.
    • Use a socket wrench to insert and tighten the screws you removed earlier. Make sure the cover is firmly attached.
    • Restore power to the AC unit by resetting the circuit breaker or following the unit's power control instructions.
    • Ensure that the AC unit is functioning properly and the air is cool.
Abschluss
By following these steps and exercising caution, you can safely replace the capacitor in your system, ensuring its continued efficiency and functionality. If uncertain, consult a professional.
Salma Hassanien
145 Reputation
1 Anleitung geschrieben
Austin Community College, Team 6-6, Watkins Fall 2023 Mitglied von Austin Community College, Team 6-6, Watkins Fall 2023
AUSTINCC-WATKINS-F23S6G6
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 46
Insgesamt: 164
