Zum Hauptinhalt wechseln
Casablanca W-11 Wall Control Switch Replacement
Was du brauchst
  1. Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: Schritt 1, Bild 1 von 3 Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: Schritt 1, Bild 2 von 3 Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: Schritt 1, Bild 3 von 3
    • Apparently W-11 is obsolete and replaced by W-32 which is also obsolete.
    • Main power switch was burned out. You can see lots of black around contacts of switch I took apart.
    • I replaced it with a rocker switch (Digikey EG1510-ND, $1 switch + $5 shipping). It's the wrong color but brown switches are hard to find.
    • New switch has on/off marking. Original switch always annoyed me because I could not tell if it was on or off.
Abschluss
To reassemble your device, follow these instructions in reverse order. Important: Buy SPST or SPDT switch or connectors won’t fit.
2 weitere Personen haben diese Anleitung absolviert.
Alan Nishioka
3.507 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 68
Insgesamt: 5,079
