Einleitung
This replacement guide of the motor involves one phillips PH00 screwdriver and use of a soldering tool. The plastic pieces are fragile, so be careful of using excessive force when taking apart the product.
Was du brauchst
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
Eine weitere Person hat diese Anleitung absolviert.
