Einleitung
Using a PH00 screwdriver, this guide will demonstrate how to disassemble the Casdon Dyson Ball. This disassembly will show how to separate the battery compartment from the vacuum ball.
Was du brauchst
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
How do I get the handle out once assembled?
