Einleitung
Using a PH100 screwdriver, a set of wire cutters, and a soldering tool, the on/off switch can be replaced in the Casdon Dyson Ball.
Was du brauchst
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
Remove the on/off switch by pulling it away from the vacuum with your fingers.
Replace the faulty on/off switch with the new on/off switch.
Ein Kommentar
Great instructions but where can you purchase the on of switch and what is the part number?
