Einleitung
This guide will show you how to disassemble the Casing of the Fellowes T7CM paper shredder.
Was du brauchst
Check to make sure the shredder is not plugged in to any electrical outlet.
Remove the shredder from the catch basket and place the silver side down on a flat surface.
Place the catch basket aside as you will not be needing it for the rest of the disassembly.
Flip the shredder silver side down and place on a flat even surface.
Remove the manufacturer's label in order to gain access to the hidden screw hole.
Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
Once all of the screws are removed, slowly pull apart the casing.
If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
Open the casing as shown to prevent tangling or damaging the wires.
Take note to how the trigger assembly is attached before removal.
The trigger assembly is one part and should come off all together with little to no force applied.
Remove the trigger assembly.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
-Group 1 Recommendations-
Use Caution - Should use the 'Caution' bullet. (Click on the bullet to change bullets)
Take note - Should use the 'Note' bullet.
Second to last bullet on the last step - Should be a note because it is not stating a step, it is a note or reminder for the user.
