Zum Hauptinhalt wechseln
Casio A158WA-1 Watch Circuit Board Replacement
Was du brauchst
  1. Casio A158WA-1 Watch Circuit Board Replacement, Circuit Board: Schritt 1, Bild 1 von 1
    • Remove the four screws from the back of the watch using a Phillips #00 screwdriver.
  2. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 2, Bild 1 von 2 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the back cover and the black rubber band with tweezers.
  3. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 3, Bild 1 von 2 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 3, Bild 2 von 2
    • Use a pair of tweezers to pull the small metal tab and remove the interior of the watch.
  4. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 4, Bild 1 von 2 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 4, Bild 2 von 2
    • Use a pair of tweezers to lift the metal clasps at each corner and remove the battery holder.
  5. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 5, Bild 1 von 1
    • Separate the LCD from the circuit board.
  6. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 6, Bild 1 von 1
    • Remember the position of the battery for reassembly.
    • Detach the battery from the circuit board.
  7. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 7, Bild 1 von 1
    • Attach the battery to the new circuit board.
  8. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 8, Bild 1 von 3 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 8, Bild 2 von 3 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 8, Bild 3 von 3
    • Place the new circuit board behind the LCD.
  9. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 9, Bild 1 von 2 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 9, Bild 2 von 2
    • Reattach the battery holder and push down on the clasps at each corner.
  10. Casio A158WA-1 Watch Circuit Board Replacement: Schritt 10, Bild 1 von 3 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 10, Bild 2 von 3 Casio A158WA-1 Watch Circuit Board Replacement: Schritt 10, Bild 3 von 3
    • Place the interior of the watch inside of the shell.
    • Put the rubber band and the lid back in their original position.
Ziellinie
1 Kommentar zur Anleitung
Hi! I believe I have this problem with my Casio royal. Where do you buy the replacements?
Bernardo Rabitti - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 64
Insgesamt: 2,159
