Zum Hauptinhalt wechseln
Casio CTK-501 Battery Connection Replacement
Was du brauchst
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: Schritt 1, Bild 1 von 2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: Schritt 1, Bild 2 von 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: Schritt 3, Bild 1 von 2 Casio CTK-501 Battery Connection Replacement: Schritt 3, Bild 2 von 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: Schritt 4, Bild 1 von 1
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: Schritt 5, Bild 1 von 1
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: Schritt 6, Bild 1 von 1
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: Schritt 7, Bild 1 von 1
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: Schritt 8, Bild 1 von 1
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jimmy Winne
578 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 9-16, Amido Fall 2012 Mitglied von Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 4,732
