Zum Hauptinhalt wechseln
Casio CTK-501 LCD Screen Replacement
Was du brauchst
  1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: Schritt 1, Bild 1 von 2 Casio CTK-501 LCD Screen Replacement, Bottom Panel: Schritt 1, Bild 2 von 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Casio CTK-501 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Completely unscrew and remove all six of the screws on the central circuit board.
  5. Casio CTK-501 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Lift the circuit board out of your way.
  6. Casio CTK-501 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove tape from the LCD screen and remove the screen completely.
  7. Casio CTK-501 LCD Screen Replacement: Schritt 7, Bild 1 von 2 Casio CTK-501 LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Replace the LCD screen and tape it down to the top cover.
  8. Casio CTK-501 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Place the circuit board back on top of the LCD screen.
    • Screw all of the screws completely in their original positions.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jimmy Winne
578 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 9-16, Amido Fall 2012 Mitglied von Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Mitglieder
3 Kommentare
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Antwort
Hi. Would this screen work for CTK 481?
José Saldaña - Antwort
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 35
Insgesamt: 5,046
