Zum Hauptinhalt wechseln
Casio CZ-1000 Barrel Plug Replacement
Was du brauchst
  1. Casio CZ-1000 Barrel Plug Replacement, Backplate: Schritt 1, Bild 1 von 2 Casio CZ-1000 Barrel Plug Replacement, Backplate: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Barrel Plug Replacement: Schritt 2, Bild 1 von 3 Casio CZ-1000 Barrel Plug Replacement: Schritt 2, Bild 2 von 3 Casio CZ-1000 Barrel Plug Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Barrel Plug Replacement: Schritt 3, Bild 1 von 3 Casio CZ-1000 Barrel Plug Replacement: Schritt 3, Bild 2 von 3 Casio CZ-1000 Barrel Plug Replacement: Schritt 3, Bild 3 von 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Barrel Plug Replacement, Barrel Plug: Schritt 4, Bild 1 von 1
    • Clean the area around the barrel plug on the board using a lint-free cloth or a paper towel to remove dust or debris.
    • This ensures a clean working surface and better visibility of the solder joints.
  5. Casio CZ-1000 Barrel Plug Replacement: Schritt 5, Bild 1 von 2 Casio CZ-1000 Barrel Plug Replacement: Schritt 5, Bild 2 von 2
    • Hold the soldering iron against the solder joint for a few seconds to melt it, then gently pull the barrel plug out while the solder is liquid.
Abschluss
Jace Alexander
181 Reputation
2 Anleitungen geschrieben
Cuesta, Team 60-3, Krynen Fall 2024 Mitglied von Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 41
