Zum Hauptinhalt wechseln
Casio CZ-1000 Display Screen Replacement
Was du brauchst
  1. Casio CZ-1000 Display Screen Replacement, Backplate: Schritt 1, Bild 1 von 2 Casio CZ-1000 Display Screen Replacement, Backplate: Schritt 1, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Display Screen Replacement: Schritt 2, Bild 1 von 3 Casio CZ-1000 Display Screen Replacement: Schritt 2, Bild 2 von 3 Casio CZ-1000 Display Screen Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Display Screen Replacement: Schritt 3, Bild 1 von 3 Casio CZ-1000 Display Screen Replacement: Schritt 3, Bild 2 von 3 Casio CZ-1000 Display Screen Replacement: Schritt 3, Bild 3 von 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Display Screen Replacement, Display Screen: Schritt 4, Bild 1 von 2 Casio CZ-1000 Display Screen Replacement, Display Screen: Schritt 4, Bild 2 von 2
    • Pull out the orange 24 pin connector.
    • Pull on the orange plastic piece and not the wires. Pulling on the wires can potentially damage the device.
  5. Casio CZ-1000 Display Screen Replacement: Schritt 5, Bild 1 von 2 Casio CZ-1000 Display Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 7.5 mm screws that are holding down the metal sheets using a Phillips #1 screwdriver.
    • Set the sheet to the side for now.
  6. Casio CZ-1000 Display Screen Replacement: Schritt 6, Bild 1 von 3 Casio CZ-1000 Display Screen Replacement: Schritt 6, Bild 2 von 3 Casio CZ-1000 Display Screen Replacement: Schritt 6, Bild 3 von 3
    • Remove the four 5.5 mm screws from the corners of the display screen using a Phillips #1 screwdriver.
    • Lift the side of the display screen that is closer to you and then pull out the screen.
Abschluss
Ayman Benbrahim
97 Reputation
1 Anleitung geschrieben
Cuesta, Team 60-3, Krynen Fall 2024 Mitglied von Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 35
