Zum Hauptinhalt wechseln
Casio DW-6900 Watchband Replacement
Was du brauchst
  1. Casio DW-6900 Watchband  Replacement, Watchband: Schritt 1, Bild 1 von 3 Casio DW-6900 Watchband  Replacement, Watchband: Schritt 1, Bild 2 von 3 Casio DW-6900 Watchband  Replacement, Watchband: Schritt 1, Bild 3 von 3
    • There are four screws— two on each side of the watch case.
    • Use the Philllips screwdriver to remove four 4.5 mm screws.
  2. Casio DW-6900 Watchband  Replacement: Schritt 2, Bild 1 von 2 Casio DW-6900 Watchband  Replacement: Schritt 2, Bild 2 von 2
    • There are two trunnions on both sides of the watch, and there are four grooves.
    • Use a small flat-blade screwdriver and push inward to remove the trunnion. And remove the strap.
  3. Casio DW-6900 Watchband  Replacement: Schritt 3, Bild 1 von 1
    • From the bottom of the watch, buckle the case from the main body of the watch by hand.
  4. Casio DW-6900 Watchband  Replacement: Schritt 4, Bild 1 von 1
    • Align the hole on the side of the case with the button on the watch and put on the new watch case.
  5. Casio DW-6900 Watchband  Replacement: Schritt 5, Bild 1 von 3 Casio DW-6900 Watchband  Replacement: Schritt 5, Bild 2 von 3 Casio DW-6900 Watchband  Replacement: Schritt 5, Bild 3 von 3
    • Thread the trunnion into the small hole on the strap.
    • First, snap one side of the trunnion into the hole of the watch body.
    • Use a flat-blade screwdriver to push the other end of the trunnion into the main body of the watch.
  6. Casio DW-6900 Watchband  Replacement: Schritt 6, Bild 1 von 2 Casio DW-6900 Watchband  Replacement: Schritt 6, Bild 2 von 2
    • Screw on the four screws on both sides of the watch.
Abschluss
Shaoguang He
133 Reputation
1 Anleitung geschrieben
York University, Team S66-G66, O'Regan Summer 2021 Mitglied von York University, Team S66-G66, O'Regan Summer 2021
YORK-O'REGAN-SU21S66G66
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 73
Insgesamt: 2,499
