Einleitung
This guide shows how to remove the front case from the rest of the Casio Exilim EX Z55 camera. You may have to do this to replace a damaged front cover or to access the inner parts of the camera.
Was du brauchst
Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
Fast fertig!
Abschluss
