Ersatzteile
Kein Ersatzteil erforderlich.
  • Open the battery door by sliding it toward the LCD screen.
  • This will reveal a small screw to the left of the memory card slot.
  • Carefully remove the screw (1.77mm).
  • The bottom panel of the camera will become loose. It is connected to the camera by two wires so do not remove completely.
Kommentar hinzufügen
We have oriented the camera with the lens up and the flash toward you for clear visibility. Use a pair of tweezers to gently move the red and black wires away from the lens.
  • We have oriented the camera with the lens up and the flash toward you for clear visibility.
  • Use a pair of tweezers to gently move the red and black wires away from the lens.
Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
  • Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board.
  • Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
  • Pull the circuit board away from the camera.
  • Be careful the circuit board is still attached to the camera by a black film strip.
  • Gently pull off the plastic cover over the LCD screen
  • Gently pull the LCD screen away from the camera. Be careful since the screen is still attached to the camera circuit board.
  • You have now completed the guide to remove the the LCD screen.
Abschluss
Jenn Eberts
Mitglied seit 10.04.2012
197 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-28, Amido Spring 2012 Mitglied von Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 Mitglieder
9 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 286
