Zum Hauptinhalt wechseln
Casio Exilim EX-Z80 Lens Replacement
Was du brauchst
  1. Casio Exilim EX-Z80 Lens Replacement, Back and Front Cover: Schritt 1, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement, Back and Front Cover: Schritt 1, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement, Back and Front Cover: Schritt 1, Bild 3 von 3
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  2. Casio Exilim EX-Z80 Lens Replacement: Schritt 2, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 2, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 2, Bild 3 von 3
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  3. Casio Exilim EX-Z80 Lens Replacement: Schritt 3, Bild 1 von 2 Casio Exilim EX-Z80 Lens Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 Lens Replacement: Schritt 4, Bild 1 von 2 Casio Exilim EX-Z80 Lens Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  5. Casio Exilim EX-Z80 Lens Replacement: Schritt 5, Bild 1 von 2 Casio Exilim EX-Z80 Lens Replacement: Schritt 5, Bild 2 von 2
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  6. Casio Exilim EX-Z80 Lens Replacement: Schritt 6, Bild 1 von 2 Casio Exilim EX-Z80 Lens Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  7. Casio Exilim EX-Z80 Lens Replacement: Schritt 7, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 7, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 7, Bild 3 von 3
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
  8. Casio Exilim EX-Z80 Lens Replacement, LCD Screen: Schritt 8, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement, LCD Screen: Schritt 8, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement, LCD Screen: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Gently flip the wide button cable up from the display cable.
    • Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
    • Carefully pull the display cable from its connector.
  9. Casio Exilim EX-Z80 Lens Replacement: Schritt 9, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 9, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 9, Bild 3 von 3
    • Pry the square holes that hold the LCD screen up with a metal spudger until you see the raised tabs in the metal holes.
    • Repeat the process with the holes around the four edges of the camera.
    • Insert the metal spudger into the gap of the metal case and pry up the LCD screen.
  10. Casio Exilim EX-Z80 Lens Replacement: Schritt 10, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 10, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 10, Bild 3 von 3
    • Hold up the LCD screen in one hand and hold back the button cable with the other.
    • Don't let the LCD screen to fall back into the metal case and make sure the button cable does not get stuck on the display cable.
    • Pull on the LCD screen until the yellow display cable is fully out of the metal case.
  11. Casio Exilim EX-Z80 Lens Replacement, Lens: Schritt 11, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement, Lens: Schritt 11, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement, Lens: Schritt 11, Bild 3 von 3
    • Lift the retaining flaps on the two ZIF connectors that secure the the lens ribbon cables to the motherboard.
    • Carefully pull the two ribbon cables from their sockets on the motherboard.
  12. Casio Exilim EX-Z80 Lens Replacement: Schritt 12, Bild 1 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 12, Bild 2 von 3 Casio Exilim EX-Z80 Lens Replacement: Schritt 12, Bild 3 von 3
    Heavy-Duty Spudger
    Kaufen
    • Turn the camera around and locate the holes on the metal panel.
    • With a heavy duty spudger, gently poke through the holes, releasing the lens from the main portion of the camera.
    • With your index finger and thumb gently pull the full lens out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 883
