Einleitung
If you would like to clean your camera or check the connections, this guide describes how to remove the battery casing on the camera.
Was du brauchst
Use a Phillips #00 Screwdriver to remove all four of the screws on the right side of the camera with the lens facing you.
Use a Phillips #00 screwdriver, unscrew all four screws on the left side of the camera.
Use the Phillips #00 screwdriver to remove all four of the screws on the bottom of the camera.
Use your tweezers to hold the camera secure, while you pull the front cover off of the camera.
Lift screen away from the camera with your tweezers.
Flip screen over gently with your fingers once it is lifted far away enough from the camera.
Use your tweezers to lift the bar holding the ribbon off.
Disconnect the ribbon to release the LCD screen.
Use your fingers to pull the LCD screen with the attached ribbon from the camera.
Use a Phillips #00 screwdriver to remove the two screws from the side of the camera that has the strap mount.
Remove strap mount by slowly pulling the side of the case so it will dislocate from the top of the camera.
Hold the camera facing toward you. Pull up the bar that is securing the ribbon located to the left of the flash.
Disconnect the ribbon by prying it off with your fingers.
With the lens facing towards you, pull the L-shaped frame away from the camera.
Remove the frame from the two studs and metal tabs keeping it in place at the bottom of the camera.
Locate the logic board to the left of the lens. You will see a bar securing a ribbon. Flip the bar up to release the ribbon.
Disconnect the ribbon.
Use your Phillips #00 screwdriver to remove the two screws connecting the frame to the back of the camera.
Lift the frame away on the LCD screen side of the camera.
This is what your camera should look like now that you have the battery casing isolated.
