Was du brauchst
With your Phillips #00 screwdriver, remove the four screws on the side of the camera.
With a Phillips #00 screwdriver, remove the four screws located on the bottom of the camera.
With a Phillips #00 screwdriver, remove the four screws on the opposite side of the camera.
Once all screws have been removed, gently pry open bottom casing.
With tweezers, carefully remove the ribbon from the LCD screen.
Set bottom casing aside.
Using tweezers, gently pry apart the top casing from the camera.
Set the top casing aside.
Use tweezers to slowly pry off LCD casing by lifting and moving it off the camera.
Use tweezers to flip open the connector holding the ribbon.
Gently pull out the LCD screen with the ribbon from the camera.
Using a Phillips #00 screwdriver, remove the two screws on the side where the battery is located.
Remove the lanyard loop after the screws come off.
Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
Carefully remove the L shaped frame from the camera.
There is a yellow and orange wire connected to camera. Be careful not to pull them off.
Using a Phillips #00 screwdriver, remove the two screws on the front of the flash assembly.
Remove flash assembly, and replace it with a new flash assembly.
Eine weitere Person hat diese Anleitung absolviert.
