Zum Hauptinhalt wechseln
Casio G’zOne Commando 4G LTE Volume Buttons Replacement
Was du brauchst
  1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: Schritt 1, Bild 1 von 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: Schritt 1, Bild 2 von 2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: Schritt 2, Bild 1 von 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: Schritt 2, Bild 2 von 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: Schritt 2, Bild 3 von 3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  3. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove Side-Front cover: Schritt 3, Bild 1 von 1
    • Pull the side front cover off the face of the phone.
  4. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: Schritt 4, Bild 1 von 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: Schritt 4, Bild 2 von 3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: Schritt 4, Bild 3 von 3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  5. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: Schritt 5, Bild 1 von 1
    • Gently pull off the motherboard cover.
  6. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: Schritt 6, Bild 1 von 1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  7. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: Schritt 7, Bild 1 von 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Gently remove the motherboard with the spudger.
  8. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: Schritt 8, Bild 1 von 2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: Schritt 8, Bild 2 von 2
    • Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
  9. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing internal volume buttons: Schritt 9, Bild 1 von 1
    • Following step 6, remove the adapter connecting the volume buttons to the motherboard.
Abschluss
Brett Boehm
281 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-5, Brown Fall 2014 Mitglied von USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 147
