Was du brauchst
Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
Press down on the screen to help remove the plastic side cover from the phone.
Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
Following step 6, remove the adapter connecting the volume buttons to the motherboard.
