Einleitung
In this guide, we will be completely disassembling the phone down to the core to remove the camera and replacing it with a new one.
Was du brauchst
Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
Flip over the motherboard
Using a spudger, lift up the small black connector and remove the camera.
Fast fertig!
Abschluss
