Zum Hauptinhalt wechseln
Casio LK-170 Display Replacement
Was du brauchst
    1. Casio LK-170 Display Replacement, Display: Schritt 1, Bild 1 von 1
      • Using JIS-1 screwdriver, remove the seven 11mm screws located on the back of the keyboard.
      Frag FixBot
      Kommentar hinzufügen
    2. Casio LK-170 Display Replacement: Schritt 2, Bild 1 von 1
      • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
      • Flip this panel up so that the component board can be seen.
      Frag FixBot
    3. Casio LK-170 Display Replacement: Schritt 3, Bild 1 von 3 Casio LK-170 Display Replacement: Schritt 3, Bild 2 von 3 Casio LK-170 Display Replacement: Schritt 3, Bild 3 von 3
      • We will be removing a total of 26 screws on the component board..
      • First, you must use the PH-1 bit to remove the 17 8mm screws, circled in red.
      • Second, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wire. These screws are circled in orange.
      • Third, using the JIS-1 bit, remove the three 7mm screws on the circuit board.
      • After removing the circuit board, three more screws will be revealed.
      • Using the PH-1 bit, remove the last three 8mm screws, circled in green.
      Frag FixBot
    4. Casio LK-170 Display Replacement: Schritt 4, Bild 1 von 1
      • Once all the screws have been removed, lift the component board and place it face down on the keys.
      • The component board is connected to the keyboard, so do not try to remove it.
      Frag FixBot
    5. Casio LK-170 Display Replacement: Schritt 5, Bild 1 von 1
      • Flip over the component board to reveal the display that is currently connected to a green panel.
      Frag FixBot
    6. Casio LK-170 Display Replacement: Schritt 6, Bild 1 von 1
      • Remove the display by carefully picking it up with your fingers from the green panel.
      Frag FixBot
Abschluss
Cal Poly, Team 13-2, Banghart Winter 2017 Mitglied von Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hey, where do you find a replacement lcd?
Albert istvab - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 975
