Zum Hauptinhalt wechseln
Casio LK-170 Speaker Replacement
Was du brauchst
    1. Casio LK-170 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 Casio LK-170 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 Casio LK-170 Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
      • Locate the seven 11mm screws on the back of the keyboard in order to remove the speaker from the front of the keyboard.
      • There are 7 screws that need to be removed in total to replace one speaker. Use a JIS-1 screwdriver to remove these screws: 2 on the back panel, and 4 on the side of the keyboard.
      • Three of these seven screws are slightly hidden and may be hard to find.
      Frag FixBot
      Kommentar hinzufügen
    2. Casio LK-170 Speaker Replacement: Schritt 2, Bild 1 von 2 Casio LK-170 Speaker Replacement: Schritt 2, Bild 2 von 2
      • Gently remove the speaker and its compartment from the front of the keyboard.
      Frag FixBot
    3. Casio LK-170 Speaker Replacement: Schritt 3, Bild 1 von 1
      • Remove the four 11 mm screws with JIS-1 screwdriver on the four corners of the silver square on the back of the speaker.
      Frag FixBot
    4. Casio LK-170 Speaker Replacement: Schritt 4, Bild 1 von 2 Casio LK-170 Speaker Replacement: Schritt 4, Bild 2 von 2
      • A soldering iron is needed to remove the wires connected to the speaker in order to fully replace it. For soldering help, take a look at the Soldering and Desoldering Connections guide.
      • Desolder the metal that attaches the blue and white wires to the speaker.
      • Remove the speaker.
      Frag FixBot
Abschluss
Cal Poly, Team 13-2, Banghart Winter 2017 Mitglied von Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
How much is a replacement speaker and where do I get one for the BRAND new keyboard U just bought that doesnt work through the left speaker (LK 265)
Heather Quigley - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 1,035
