Zum Hauptinhalt wechseln
Casio MH-10M Battery Replacement
Was du brauchst
  1. Casio MH-10M Battery Replacement, BATTERY: Schritt 1, Bild 1 von 1
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Casio MH-10M Battery Replacement: Schritt 2, Bild 1 von 2 Casio MH-10M Battery Replacement: Schritt 2, Bild 2 von 2
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Casio MH-10M Battery Replacement: Schritt 3, Bild 1 von 2 Casio MH-10M Battery Replacement: Schritt 3, Bild 2 von 2
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Casio MH-10M Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Casio MH-10M Battery Replacement: Schritt 5, Bild 1 von 2 Casio MH-10M Battery Replacement: Schritt 5, Bild 2 von 2
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
Abschluss
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
26 weitere Personen haben diese Anleitung absolviert.
Sam
977 Reputation
1 Anleitung geschrieben
3 Kommentare zur Anleitung
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Antwort Teilen
what battery size is it? R03?
Humerdom - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 28
Letzte 30 Tage: 80
Insgesamt: 49,925
