Zum Hauptinhalt wechseln
Casio MTD-120 Battery Replacement
Was du brauchst
  1. Casio MTD-120 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the watch upside down.
  2. Casio MTD-120 Battery Replacement: Schritt 2, Bild 1 von 2 Casio MTD-120 Battery Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Casio MTD-120 Battery Replacement: Schritt 3, Bild 1 von 2 Casio MTD-120 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Casio MTD-120 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Casio MTD-120 Battery Replacement: Schritt 5, Bild 1 von 1
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Casio MTD-120 Battery Replacement: Schritt 6, Bild 1 von 2 Casio MTD-120 Battery Replacement: Schritt 6, Bild 2 von 2
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Casio MTD-120 Battery Replacement: Schritt 7, Bild 1 von 1
    • Put the cover back and tighten it shut by pressing on it.
Abschluss
Follow the link provided in step 5 to find more information on recycling your old batteries.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 4,533
