Einleitung
Do you have a Casio Edifice watch with a broken or ill-fitting band? Use this guide to fix or resize the watchband and return the watch to its former glory.
Was du brauchst
Locate the hole for the pin you would like to remove.
Insert the Sim Card Eject tool (a safety pin may work as well) inthe hole. Make sure to insert in the hole on the back side of the arrow.
To remove links:
Use the same process used in Step 2 to remove the second link pin.
The two link pins and the links should now be detached.
To add links:
Push both link pins back into the watch. Make sure to insert the link pin on the front side of the arrow.
Lightly tap a hammer until pins are flush against both sides of the watchband.
For micro adjustments, push the Sim Card Eject tool into the adjustable side of the clasp. Carefully move pins to the correct fitting holes.
Insert spring into the spring bar.
Insert the spring bar pin on both sides of the spring in the spring bar.
This is the spring bar pin.
Put the spring bar and spring bar pins through the end of the clasp.
Guide one spring bar pin into the hole on the clasp shell. Hold your finger on the other side of the spring bar to keep the parts together.
Squeeze the spring bar so it fits within the metal sides of the clasp.
Guide the other side of the spring bar into the other hole.
To disassemble the clasp, follow the last 3 steps in reverse order.
8 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
These are good tips. Repairing a watch can be tricky especially if moisture creeps in. If you're stuck for help, check out http://TimesTicking.com I have used them many times. Very helpful!
Hi, where can I buy link pins? I have the ones with the spring, but the others - I have not been able to find online.
Here is good chanal for watch repairing https://www.youtube.com/watch?v=n1FQgn95...
