Einleitung
The keypad of the Casio Classpad II (fx-CP400) may require some cleaning between the rubber dome switches and PCB. Use this guide to disassemble and clean the keypad.
Was du brauchst
Remove the batteries and battery cover.
Remove the 6 Phillips head screws from the back of the calculator.
Start with the left side of the calculator:
Wedge a plastic opening tool into the bottom of the calculator (where the keypad is) and slide it up to the clip (see photos).
Push the clip in and pull the front plate away from the white frame.
Repeat for the right side of the calculator.
Carefully remove the front plate from the white frame of the calculator.
Remove the 2 Phillips head screws holding the keypad PCB to the front plate of the calculator.
Lift the keypad PCB and remove the rubber membrane.
Clean the bottom of the keypad PCB with alcohol wipes and dry thoroughly with cotton swabs.
Similarly clean the black contacts on the rubber membrane.
